- psalm10720ExplorerThanks. At a campground doing that now..
- DachristianmanExplorerI have a 92 Brave and my coax cable has long rusted away. I'm not sure how moisture got inside, but the center solid core is gone. I'm sure yours is the same way.
If you can find a good connection inside, I would just tap into it with a splitter and run the cable out the window. You could easily run it under the bench seat and install a hook-up next to your radio. It would be pretty simple to do and it would be a permanent solution.
Tom - psalm10720ExplorerThanks. Tried it. Something wrong with it.
- RoyBExplorer IIWhat I do is bring along a TV SPLITTER with a short male to male RG cable to hook up to the campground pedestal and then hookup my trailer the normal way to one port and then add a 25-foot RG cable to the other port and throw that under the RV so I can use it under the awning when we want to sit outside and watch TV sitting on an outside table next to the RV.
Photo from google search
Works for us.
Roy Ken - bsinmichExplorerHave you checked the top of all the compartments very close to the door frame?
38,766 PostsLatest Activity: Jan 10, 2026
