I know my 2013 model on the F53 has the wires for driving lights and a blank plate on the dash. I assume most models are this way. Since it's an option the wiring harness is prepped to handle a plug and play. The tricky part is mounting as it would require me to cut a mounting hole in the fiberglass where they would "normally" go. But otherwise they would simply plug right in. You may want to check with the manufacturer as they may already have a kit that gets included as an option.
