mercedesme28 wrote:
Here is an off-the-wall question , I was looking on Amazon.com and found it inverter that you can plug into your cigarette lighter/PowerPort or connect directly to the battery it is 1000 W my question is I have a very small portable AC that is I was looking on Amazon.com and found it inverter that you can plug into your cigarette lighter/PowerPort or connect directly to the battery it is 1000 W my question is I have a very small 15amps and draws 8 Amps,
I was hoping to run this while driving in these triple digit temperatures help keep the motorhome cool while driving instead of turning on the generator to run the roof air do you think this 1000 watt would work it says it can run a appliances and TVs ?
Can it destroy my battery car overheat my battery while driving ?
Like I said another' odd question...
Thanks
Most of these inverters won't work at all on a 12vdc port and certainly not to the tune of 80amps with no more than #12awg feeding it. Even when directly connecting to the batteries, stay close by at 5ft max runs and use a min. of #2awg.
Like said, run the gens set for these kind of loads.
