Gundog wrote:
I would like to add a couple more seat belt positions to our 2005 34H Fleetwood Expedition. The coach has 5 seat belt positions now the 2 front seats and 3 on a sofa. My thought is to add 2 to the forward facing seats at the dinette I would remove the table because I see no way of securing it in an accident. I would make sure the lap belts are secured to a frame structure. Is this an OK modification I am just looking for opinions no lectures.
Here is a link to the brochure showing the floor plan mine is the 34H.
Fleetwood Expedition brochure 2005
Thanks Mike
If the seat belts are going in the slide out area than the frame will not be located under the slide out, its OK to go thru the wood floor and use either a small thick metal plate or very large thick washers under floor with the largest bolt the seatbelt bracket offers, that will be strong enough at most higher speed accidents..
