rdl1155's avatar
rdl1155
adding xm/sirius antenna
Has anyone added XM/Sirius Antenna on top Class A Coachmen Mirada/Pursuit - want to mount antenna on roof and run cable inside between window post and trim down under dash board. Original coach clearance lighting wires, TV & radio antenna wires, etc. already running down in that location. Believe I can get access to all areas but before I begin to remove panels I wanted to know of any concerns I need to be aware of if someone else had tried this.
  • added a magnetic mount INSIDE on the roof frame by going up the pillar containing the radio antenna. JM2¢...
  • when I had an add on xm receiver, IIRC I bought a remote antenna that had a suction cup that held it on the windshield. worked fine inside the vehicle.
    bumpy
