CloudDriver
Nov 28, 2014Explorer
Our day/night shades have two piece "spools" for adjusting the string tension. By loosening the center screw, I can pull the portion of the spool that has the cord wrapped around it away from the fixed portion of the spool that is screwed to the RV wall. There are 4 pins on the cord portion that fit into the fixed portion to keep the spool from turning from the tension. By loosening the center screw, I can pull the pins free and rotate the spool in 1/4 turn increments. Usually 1/4 turn tighter is enough to keep the blinds up.
The pins are visible in the picture.
38,769 PostsLatest Activity: Apr 03, 2026
