Goldencrazy's avatar
Goldencrazy
Window awning tension
One of my window awnings has lost its tension . It worked this summer but this the first time I have tried it since then. It has been through some winter snow and cold but was retracted. I am sure ther is a way to restore the tension but it is not in my knowledge base. Can anyone help before I spend the money to have it fixed. It is only one year old.Thanks.
  • 2 of my Carefree window awnings keep falling or blowing open while I am on the highway - is there an easy way to tighten them up? My installation instructions do not indicate any method to tighten them?
  • Here is a link to Dometic. They have a number of manuals online. Maybe it will help. Clicky
  • I have been messing with it. First I tried to lubricate everything that moved and did get it to close and open but not smoothly. Finally it refused to close but I was able to hand roll itin ut it was very tight. It is a dometic but I don't know how it works inside the roller.
  • You may need a new spring -- our main awning did this and when disassembled the spring was actually broke on 1 end. Awning would not roll up tight like it should no matter how many times we tried.
  • I'm thinking it may be the spring is stuck so will lubricate and see what happens. Any experience would help.
  • Don't know which brand you have but most have a good website full of good info on this subject.
