Effy
Jan 09, 2014Explorer II
dougrainer wrote:clayway wrote:
Eddy, not sure this will work for you but I had the same issue.
I took off the dome cover than manually adjusted it so it picked up the signal (compass is needed). Works after that
This is from Winegards manual. I have worked on and FIXED dozens of Winegards and have NEVER had to do or have heard of such a thing. Doug
The Mission antenna is designed to be maintenance free. However, it is a good
idea to clean the dome from time to time with a soft cloth, water and dish soap
All I can tell you is they said they did an adjustment at the advice of winegard
38,782 PostsLatest Activity: Aug 31, 2026
