Effy
Jan 10, 2014Explorer II
Bill.Satellite wrote:
I think the dealer "got ya"! There are no mechanical adjustments or software updates that are available for a Winegard dome antenna. More than likely they made a change to your receiver setup or cabling to resolve the issue.
Exactly what model DirecTV receiver are you using? Do you use this in your home and move it to the RV? Have you done the Repeat Satellite Setup routine? Any additional info would be helpful.
Not sure the model receiver, it's an older (dark grey model). Yes it can be used at home or in the RV. I have noticed when the dome is trying to find the signal there was a new noise, almost like a grinding or slipping of the belt. Is this possible and could cause the issue? I have done the set up routine. I have called DTV to ensure the reciever can accept a signal and tested it in the house. I am at a loss at this point. The dealer seems to know how to fix it but I'd rather not spend another $100. Originally I thought it was the small black receiver (forget what it's called (DNS??)) but they said no.
38,782 PostsLatest Activity: Aug 31, 2026
