Effy
Jan 10, 2014Explorer II
Bill.Satellite wrote:Effy wrote:
Never switched the cables. It sees the dome, let's me know it's finding Sat, it just never locks on. After a while it just goes to sleep.
There is nothing inside your coach that would let you know it's finding the sat. Any message you may see on the TV is from the receiver and the receiver has no idea what's going on with the dome.
I believe your receiver is the issue. That is not a model number I am familiar with and must either be quite old or not appropriate for this installation. Can you tell us more? Manufacturer name? Is there a card in a slot somewhere is more info? Anything will help but need more info.
OK, I Googled that model number and that does appear to be your problem. That's a really old Samsung receiver and is likely not compatible with your dome. You will want to get a new receiver (D12 if you don't use it at home as it is SD only) or a new HD receiver but it must have a model number of H24 or lower to be compatible.
I hear you but it worked before. Why would it stop? I can try a newer receiver we have here in the house . Will report back later tomorrow eve. (Day is all booked up tomorrow )
Thanks for your help and follow up.
38,782 PostsLatest Activity: Aug 31, 2026
