n4hwl's avatar
n4hwl
advice on a 2010 Tiffin Zephyr
I have found a 2010 Tiffin Zephyr that I am seriously considering buying. It has 33,000 miles on it. I understand that this 10.8 liter cummins engine used a def system. If I remember correctly this was about when the def was starting to be used and I assume this is one of the very early systems on this coach. I am just wondering if anyone has experience with this engine and if there are any common problems i need to look out for. I know the common wet bay floor, slide floor and roof radius I need to look at. Any suggestions, concerns or warnings on this vintage Tiffin?
Thanks
Ken
  • Or, many of the tiffinrvnetwork people also are on the Tiffin facebook page and you will get a much faster (but not necessarily better) answer to your question.
  • You might consider joining and posting your questions on the Tiffin Owners forum.
    Tiffin RV Network
    There are a lot fewer Zephyrs around than other Tiffin models, but there might be someone there that can help.
    Update: A little web searching indicated that it may have a pre 2010 ISM engine or possibly an ISX engine. I suggest you try to get the engine serial number and verify with Cummins.
