BiggYella's avatar
BiggYella
Advice on a Class C
Our family has decided it may be time to get rid of our 37.5 ft 5th wheel and replace it with a 25-32 foot class C motor home. This is our second time considering this and I’m looking for the collective wisdom of the board.
Our ideal is a new or newer class C capable of pulling a 3-horse trailer occasionally (between 6000-7000 lbs - kids do 4H and B horse shows) within a 300-500 mile radius of our home and also capable of pulling our CRV for longer family touring trips. We need to sleep 4-6 comfortably and the wife would like 8 seatbelts. We want 1-2 slides and a built in generator.
If any of you have experienced with brands and models, please share it!
Thanks in advance!
  • MDKMDK wrote:
    With that towing, sleeping, slides, and generator requirement, you're into a Super C diesel, or a diesel pusher. Not many typical gas engine class C motorhomes can meet those numbers.
    X2
    Another consideration is while you "might" be able to sleep that many in a standard Class {regardless of the size} where are you going to put their stuff? You won 't have much payload to begin with and loading as the OP proposes will quickly eat that up.
    Get a Super C or find a Plan B.
    As always... Opinions and YMMV.
    :C
  • I don’t think i have ever seen an rv that sleeps 6 and belts 8 . Where would you belt them in ?
    In the dinette ? For 500 miles ?
    How about thinking about following in the car and adding a tent.
  • X2, mdk. At 1200 pounds per horse, 3 bales of hay plus tack, trailer will be more than you estimate. Your estimated range of 300 to 500 miles has no bearing.
  • With that towing, sleeping, slides, and generator requirement, you're into a Super C diesel, or a diesel pusher. Not many typical gas engine class C motorhomes can meet those numbers.
