LenoExplorerNov 26, 2013Advice on Heater Not Blowing Warm AirI have a 2001 Four Winds Class C. Used the heat two nights ago and all was well. Yesterday ran out of propane and had it filled. Now the heat will only blow cold air. The propane is turned on and oven...Show More
DakzukiExplorer IINov 26, 2013You may need to burp the system due to air in it. Turn on a stove burner and when it stays lit try the furnace again.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsBattery Fuse BlowingWater Heater Leak on start up.Replace insulation inside heater column.
