LenoExplorerNov 26, 2013Advice on Heater Not Blowing Warm AirI have a 2001 Four Winds Class C. Used the heat two nights ago and all was well. Yesterday ran out of propane and had it filled. Now the heat will only blow cold air. The propane is turned on and oven...Show More
LenoExplorerNov 27, 2013Just to let everyone know. A friend suggested turning the propane off and then on again. It worked! All is good.. Thanks everyone
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsBattery Fuse BlowingWater Heater Leak on start up.Replace insulation inside heater column.
