clotus wrote:
I have the opportunity to switch over to a 2007 Bigfoot 32ST Super C on the Kodiak 5500 chassis with Duramax diesel. Owned by my in-law and meticulously maintained. Floorplan isn't to my preference, but not is not far off.
I have always wanted a Super C, but I am concerned that due to the age and Bigfoot not making motorhomes since 2008, I do not want to get into something older that requires more work with minimal support available.
Getting something you "want" with a known history and in great shape is a huge plus.
Regarding the chassis, I presume it's pre- tier IV emissions. The 05-07 LBZ Duramaxes are now kind of considered the "holy grail" of Duramax trucks. Had an 02 that was flawless (in a pickup).
Cool factor of a diesel and a Super C is off the charts if class Cs are your thing and you'd have more/efficient towing capacity.
Regarding the camper itself, generally campers are technological relics and also generally very similar for appliances or electronics.
Fit and finish aside, regardless of what brand you buy, youre likely getting the same "components." Having had a 2005, 2003 and now a 2017 camper, over the last 8 years or so, I don't see a measurable advantage to newer vs older for reliability.
And regarding value, yes, good time to capitalize on a sale and an even better time if you're getting a "deal" on the new one.
Subjectively, even once the market normalizes, or even if it gets bad, I feel a Bigfoot Duramax Super C will retain better value % than the million run of the mill class Cs and other high volume RVs.
