mitchymomma's avatar
mitchymomma
Advice please Leaking Rubber roof Travelcraft
The roof on our 1970's RV split. An interim owner had put on a rubber roof. (they purchased it from us years ago, then we purchased it back years later) We'd been trying to keep it sealed, but now, the rubber has split in several places and leaked all through to the inside. The interior ceiling has to be removed and replaced due to massive water damage. That part we think we can figure out.
Is there a way to repair the roof without removing the entire thing? We're not really even sure that would be possible since it is an aftermarket rubber roof, which was probably installed with contact cement. Also very confused on if there are any products that will actually stick to the rubber if we try to do a thorough patch job. We really can't afford $1000-$3000 to have the roof professionally redone. We've even wondered if there are other options of materials (ie: metal roofing) that we could use
Any suggestions? Would sincerely appreciate it. This is the RV my teenage son has grown up camping with his grandparents.
  • There have been members that have sprayed the roof with the same material that is sprayed on the floor of a pickup box. Rhino is one of the material used - Click Here.
    Not cheap, but as permanent as you can get.
  • For larger areas which it SOUNDS like you have, you can purchase EPDM material from many commercial roofing companies and create a patch glued to the old roof material and caulked at the edges or eternabonded instead of caulking (your call). I would recommend that the patch overlap the edge of the part that is damaged by six or eight inches.
    Good luck / Skip
  • Clean it good and use strips of eternabond. It worked great for me a few years ago and you can buy online from Walmart
