FIRE_UP
Sep 29, 2013Explorer
Geocritter,
Well Sir, as has been stated, a 3/4" gun will deplete your "intended" little compressor almost instantly. I too have had the pleasure of having home air, a Sears 20 Gallon, two horse unit for the first 20 years and the one we have now, a 30 Gallon, 3 horse unit for about 19 years. This 3-horse unit is set for 150 psi cut out. It will handle a 3/4" gun, efficiently for about 10-15 seconds of full trigger pull. After then, it's no more power than a reasonable 1/2" gun.
Yes, you need MASSIVE volume and, at sustained psi. in order for full value of high torque tools to operate efficiently. I too like air tools and having the ability to use them if and when needed. But, in reality, just how much "big" work are you or I, planning on doing while out on the road? I too do all my own work and, it's very handy to have air tools giving assistance when and where needed but, a couple of things prohibit this.
1. Like what's been stated, you need high volume and high pressure for just about any of them to be of real value.
2. And, since the one you're thinking of is not anywhere near what you'd need one for, you'd need a seriously larger one to accommodate the drive needed for those tools, and you say you don't have the storage capacity for such a large unit.
3. Then, there's the tools themselves. There's lots of weight there and, volume of space needed for, whatever ones you plan on toating with you on your adventures.
Don't get me wrong here, I commend you for thinking that way. Being as prepared as one could be is always nice. I was thinking along the same lines when preparing for a "just in case" situation with my lug nuts, if ever the need arose for removal. 450 ft.lbs. of torque is fairly tough to deal with out on the road or, even at home most of the time. So, long story short, I was thinking of a 3/4" gun and large volume hose, adapters for small line to big line etc. etc. but, instead, I purchased a Torque Multiplier that is seriously strong enough to break those lug nuts loose, if ever needed.
So, just some info for you if it's of any value. Take care.
Scott
Scott
38,771 PostsLatest Activity: Apr 13, 2026
