Farmerjon
Sep 23, 2016Explorer
Since you are a performance guy you already understand the power band of engines and the diesels are the same as gas just everything begins and ends sooner in the rpm band, but the torque is amazing compared to a gas engine.
You have to be careful about clean fuel, but you already are.
As several have said you can still do your own maintenance it really isn't any different.
Buying used is scary and we decided not to, but a pick up is a lot less money than a large motor home. I would think if you find a nice DP it would be worth while to have someone familiar with that motor inspect it after you have been satisfied about past maintenance and repairs.
Good luck
Good luck
