Gjac
Sep 24, 2016Explorer III
To me the question is not gas vs diesel but what size MH do you want. For most of us buying any MH is a big purchase and you want to get the "right" one. If you want to stay small 34 ft or less I think a gas MH makes more sense. 36 ft to 43 ft a DP makes more sense. What I have noticed is that the bigger the DP gets the bigger the eng is and the more HP it has. A gas MH has the same eng whether it is 30 ft or 38 ft. Having raced motor cycles you understand that it is the HP/WT ratio that determines performance. A 30 ft MH will have 362HP and weigh 15,000 lbs a 36 ft DP may have 360-380 HP but weigh 28,000 lbs. A 40-43ft DP may have 500 hp but weigh well over 30,000 lbs. A 32-34 ft DP if you can find one may have 190-300 HP. So if you want to stay small like your older 30ft Allegro a 362HP Ford or a 340 HP WH will in general will have better performance than most DP's. The decision is harder in the 34 to 36 ft range.
