k_jensen6
Dec 27, 2013Explorer II
After market brake system
We have a 2001 38' HR Imperial with an engine brake but not an exhaust brake. Has anyone had a brake assist system installed? If so, what kind and are you satisfied with the result?
jtfcons wrote:
Some clarification here, please.
An exhaust brake is the entry level engine brake that coach manufacturers put on diesels. Engine brakes that operate the engine valve train to achieve back pressure are the next level, more expensive, more efficient.
Is your question about auxiliary brakes on towed vehicles, I'm confused, but that's not unusual:)
I see from your other post that we are discussing engine brakes not towed vehicles.
The exhaust brake is a device that will be installed in the exhaust piping immediately downstream from the turbo charger at the top side of the engine usually. It will have a small air cylinder that moves a lever attached to a flapper valve in the exhaust system to block exhaust flow and cause backpressure to slow the vehicle. This in combination with gear downshifts does a pretty good job. If you feel this is not working as expected Jacobs has updated the system with the PRX model(I think) that has received good reviews. Before investing too much though, I would check whether the unit is lubed and working properly, a DIY job if you're handy. Lack of proper maintenance is a major reason for complaints of lack of performance. Also the transmission downshifting is supposed to happen automatically, so check that as well.
