Artum_Snowbird
Jul 02, 2014Explorer
Water pump may be because you left the rig and your last hookup was with the water hose to an outside tap.
Essentially, you get some water flow, but very little, and the water cannot build up pressure and just circulates. Check your valves and be sure on that one.
Your fridge has a 120 volt plug in behind the outside panel, check that with a meter and see if you have good power first.
Read the manual, sometimes there might be a reset, or an error code on the LED readout.
Nothing to worry about, just do your homework and enjoy it.
38,769 PostsLatest Activity: Apr 03, 2026
