RLS7201
Jun 30, 2021Explorer II
Once you consider the cost of 19.5 tires and wheels. Think about the best 235/85R16 tire for your MH. Michelin XPS is the tire Ford picked as OEM, for a reason. The XPS has all steel cord construction and that helps eliminate tire side wall flex. I run nothing but Michelin XPS tires on my coach with never a problem. The drive and handling is good.
You current 235/85R16 tires are 32" in diameter. Try and maintain the diameter if you insist on changing wheel size.
Richard
Richard
