Peteponic's avatar
Peteponic
AGM batteries, overcharging on long drives
I am new to AGM batteries and have done a lot of study prior to purchasing them as a replacement for my coach batteries. My charger has a specific algorithm for charging them when plugged into shore power so I have no concerns here.
What has been nagging me is what happens when I take off on a long (several 100 miles) drive starting out with fully charged batteries. During this drive the battery separator will deliver alternator power to the batteries for the whole drive.
Should I be concerned? Should I add a switch to disable the battery separator under these conditions?
I would appreciate any thoughts or ideas.
  • Like you, I start out with fully charged batteries (both house and chassis batteries) from being plugged in. Instead of a switch to turn off the charging voltage, I run the fridge off the inverter while driving. It keeps the voltage at the house batteries just below 14 volts during the drive. From memory, I think it is 13.9 volts which is a bit better I think than hitting them with 14.4 volts for hours when they are already fully charged.
    If your fridge has a DC option then that might also keep the voltage at the house batteries at a more acceptable level.
    My only concern would be that the charging voltage of the vehicle voltage regulator may be set at a higher voltage for conventional lead/acid batteries. This could lead to possible over charging.
