btilfan's avatar
btilfan
aiming my directv dish
I know to aim at the directv 101 and that works for me but the last time I had a installer out he said you want to pick up two sats. When I aim at the 101 I only get channels 70 and up. when he aimed it I got all including 1 thru 70. It looked like his was a little off of the 101.
Is there something else I should be aiming at? I use sat finder app to line up with 101.
  • Direct uses three birds 99,101, and 119 I believe. If your using a sat finder app set all three then you center on 101 the other three should hit. Unless your using the old style round dish.
  • Depends on what dish you are using. Only the slimline will get HD on 3 sats. You need to adjust elevation, azimuth and skew. 18" SD dish will only get the 101 and the receiver has to be set for it. Chuck
  • we used one the other weekend in the mountains of NC.
    We used a dual LNB and hooked two campers with home sets to see DirectTV.
    We just aimed based on the permanently mounted ones around us in the permanent sites. We got our BASIC DirectTV with what each of has as our packages at home. I had my local channels and all the others. I had to change my set up from SWM, multiport 32" dish that I use at home for HD and all the other stuff. To use an 18" dish I have to take the multiport out then reselect my set as an 18" dish. Programming is the same as home except I don't have FULL HD.
    Most of the time with us being on the east coast the angle is almost so close we don't adjust it, we just have to turn VERY, very slowly to catch the dish. never had a problem but I also keep my extra receiver on full time for an extra $6 a month, but I have the cable ran to the camper as it rest's under its shelter. So anytime I am at home I can turn tv on see DirectTV.
    randy
