10forty2
May 24, 2016Explorer
Firestone Quad Controller
Sorry...should have thought about that before I posted. It's the Firestone standard duty compressor and wireless Quad Controller model 2500. There are 2 separate valve blocks, one for front and one for rear, that allow control of each corner bag separately (left and right air output ports on each valve block along with 2 pressure sensors). Coming from the ECU module, there are 2 plugs, one for each of the valve blocks (I assume that one controls the front valve block and the other controls the rear valve block). There are also 8 separate wires, different colors, one for each terminal on the pressure sensors. There is no different marking for each valve block or for the pressure sensors. I would have thought, even though they are the same parts, since it's sold as a kit that is sold as supposedly "easy to install" it would have some markings or at least some detailed instructions in the kit.
Unfortunately, I have not found in the instructions, the proper connection to make sure I'm not inflating the right rear when I push the button to inflate the left front. Maybe it's hidden in the text somewhere, but I can't seem to find it. I have sent a request to Firestone Technical Support, so we'll see what I get back. Otherwise, I guess I'll be doing the trial/error thing and marking it as I find the proper sequence.
38,766 PostsLatest Activity: Jan 10, 2026
