10forty2
May 24, 2016Explorer
rgatijnet1 wrote:
It looks like violet and tan wires controls the rear block and orange and blue wires for the front block.
That is why they label two different wheels on the block for each wire. For instance if you are wiring the rear block for the RR air bag it would be controlled by the violet wire. If that same block was used for the front air bags then it would be the blue wire for the RF.
Guess I got a 50/50 chance, huh? I'll snap some photos and try to post them so you can get a visual. I get to determine which block controls front or rear by determining which block I run the air lines from to front or rear. What I don't know, is which plug from the ECU is programmed to control front or rear. I could easily make the front valve block in the diagram control the rear air bags by simply running the air lines to the rear air bags, but intuitively, I want the wireless controller to inflate the left front air bag when I push the button associated with the left front air bag. The wiring instructions don't say which is which.
38,766 PostsLatest Activity: Jan 10, 2026
