Tinstar
May 15, 2016Explorer
Here's the procedure (copy and paste) for the DOT air brake system checks. I know all of this won't apply to your coach since you do not have a trailer being towed but maybe it will help you find if you have a system leak or maybe it's just the governor.
Test Low Pressure Warning Signal. Shut the
engine off when you have enough air pressure so
that the low pressure warning signal is not on. Turn
the electrical power on and step on and off the
brake pedal to reduce air tank pressure. The low
air pressure warning signal must come on before
the pressure drops to less than 60 psi in the air
tank (or tank with the lowest air pressure, in dual
air systems).
If the warning signal doesn't work, you could lose
air pressure and you would not know it. This could
cause sudden emergency braking in a singlecircuit
air system. In dual systems the stopping
distance will be increased. Only limited braking can
be done before the spring brakes come on.
Check That Spring Brakes Come On
Automatically. Continue to fan off the air
pressure by stepping on and off the brake pedal to
reduce tank pressure. The tractor protection valve
and parking brake valve should close (pop out) on
a tractor-trailer combination vehicle and the
other combination and single vehicle types when
the air pressure falls to the manufacturer’s
specification (20 – 45 psi). This will cause the
spring brakes to come on.
Check Rate of Air Pressure Buildup. When the
engine is at operating rpms, the pressure should
build from 85 to 100 psi within 45 seconds in dual
air systems. (If the vehicle has larger than
minimum air tanks, the buildup time can be longer
and still be safe. Check the manufacturer's
specifications.) In single air systems (pre-1975),
typical requirements are pressure build-up from 50
to 90 psi within 3 minutes with the engine at an idle
speed of 600-900 rpms.
If air pressure does not build up fast enough, your
pressure may drop too low during driving, requiring
an emergency stop. Don't drive until you get the
problem fixed.
Test Air Leakage Rate. With a fully-charged air
system (typically 125 psi), turn off the engine,
release the parking brake (push in); and time the
air pressure drop. The loss rate should be less
than two psi in one minute for single vehicles and
less than three psi in one minute for combination
vehicles.
With the air pressure built up to governor cutoff
(120 – 140 psi), shut off the engine, chock your
wheels (if necessary), release the parking brake
(all vehicles), and the tractor protection valve
(combination vehicle); and fully apply the foot
brake. Hold the foot brake for one minute. Check
the air gauge to see if the air pressure drops more
than three pounds in one minute (single vehicle) or
four pounds in one minute (combination vehicle). If
the air pressure falls more than three psi in one
minute for single vehicles (more than four psi for
combination vehicles), the air loss rate is too much.
Check for air leaks and fix before driving the
vehicle. Otherwise, you could lose your brakes
while driving.
Check Air Compressor Governor Cut-in and
Cut-out Pressures. Pumping by the air
compressor should start at about 100 psi and stop
at about 125 psi. (Check manufacturer's
specifications.) Run the engine at a fast idle. The
air governor should cut-out the air compressor at
about the manufacturer's specified pressure. The
air pressure shown by your gauge(s) will stop
rising. With the engine idling, step on and off the
brake to reduce the air tank pressure. The
compressor should cut-in at about the
manufacturer's specified cut-in pressure. The
pressure should begin to rise.
If the air governor does not work as described
above, it may need to be fixed. A governor that
does not work properly may not keep enough air
pressure for safe driving.
Test Parking Brake. Stop the vehicle, put the
parking brake on, and gently pull against it in a low
gear to test that the parking brake will hold.
Test Service Brakes. Wait for normal air
pressure, release the parking brake, move the
vehicle forward slowly (about five mph), and apply
the brakes firmly using the brake pedal. Note any
vehicle "pulling" to one side, unusual feel, or
delayed stopping action.
This test may show you problems, which you
otherwise wouldn't know about until you needed
the brakes on the road.
air systems).
problem fixed.
vehicles.
while driving.
