Dutchstar02
Sep 14, 2015Explorer
wilco wrote:
CAVEAT. It was 10 years ago and the rules could certainly have changed but here's what was required at the time: having a general Ontario driving license, I took a written test based on the air brake booklet provided/purchased. Once passed, there was a stationary "practical" test that mostly involved running the test vehicle through the daily checks that one should do prior to driving a vehicle with air brakes. You had to provide a suitable "test vehicle" at the testing centre at the time of the appointment. There was no road test.
My advice: Firstly, ask your dealer what is required to drive the thing you want to buy. Take that as a starting point then call an actual licensing centre and ask them what you need to do to get your air bake qualication.
The stuff you're talking about is the air brake endorsement part only. BTW that test has to be rewritten every time your licence is renewed (5 years). There is no practical required on the rewrite only 20 questions (16 correct for a pass).
The issue with the road test is that you will need a commercial D licence to operate any vehicle in excess of 11,000 kgs. If your gas powered MH weighs more than 11,000 kgs you still need the D license. MTO doesn't care if your driving a motorhome or a dump truck the licensing requirements are the same. The hardest part of the test is the safety walk around. You have to hit all the requirements in a reasonable amount of time. Without taking a truck driving course the chances of that are slim to none. My previous comments on getting the endorsement first and then the commercial D license through a school using a gas powered school bus is the easiest way. I did this all 6 years ago and had to do the rewrite when my licence was renewed.
5th wheel drivers have it somewhat easier in that they can get a restricted A licence to tow their trailer that weighs in excess of 4,600 kgs but if the combined weight of truck and trailer exceeds 11,000 kgs then they have to have a different A licence (no Z endorsement because the truck doesn't have air brakes). A full A licence allows towing in excess of 4600 kg and Z endorsement.
Don't trust what a salesman tells you. I was told I didn't need anything other than a G licence because the MH wasn't a commercial vehicle. The only thing not required for a MH is the CVOR inspections every year. If you take it into a truck service center for maintenance they may tell you you need the inspection but you don't. The MH is licensed the same as your car.
38,782 PostsLatest Activity: Sep 10, 2026
