need a air compressor for a class c motor home. Do not have a lot of room. size of tires is 225/75/16 10 ply. Bought a small compress takes way to long and to noisy. need one that will do 80lbs. Maybe...
9" height fits in my Class C outer storage. 1 gal tank, 135 psi. Good for tires And blowing out water lines for Winterizing. This is handy if you need to Winterize on the road. Same unit also sold under different branding.
I also gave away the Big compressor since this works well.
For tires Only, might consider a high output tank-less like the 4x4 truck guys use. Much smaller.
