MagillaGorilla wrote:
My suggestion is to get a small compressor that has a true output of over 125 PSI. That way you can pump up your RV tires too. Why not have one that fills every tire you have with you?
The one I have came from Lowes and was under $150. It is a small compressor with a tank. It takes a while but it can fill my 110 PSI RV tires too and believe me you want to make sure your RV tires are set to the correct levels.
Yeah, I need to take a closer look at those and see if I want to store/carry it around in my RV. Certainly feels like the right answer.
