krinderhagen
Jan 08, 2014Explorer
Ivylog wrote:
Until this post, all have been about your generator troubles. One of the last ones said you had one AC working on the generator after swapping parts from your Mom's plus problems with your transfer switch. Do you have power to your 120V outlets while using the generator? With a 5K generator some MHs have a switch that lets you select between the microwave and the second AC unit although you imply that you have a management system. We need more info and I'll assume you have checked the breaker on the generator.
yes checked all breakers 110 is there i don't have amp meter at the moment cant find switch for did replace the Carburetor with new computer with new and relay switch for show and generator is new
i was expecting the generator to bog or chnage RPM when switching on the generator
Breaker panel ac control panel operation
Generator run
38,767 PostsLatest Activity: Sep 19, 2016
