krinderhagen's avatar
krinderhagen
Air Conditioner Works on shore power not the Gemerator
The Air Conditioner
Well both the air conditioners work when plugged into the shore power, however neither of the Air conditioners work on generator power. there is a amp sensor on the top breaker for the front AC i believe it senses the amount amps available telling the computer whether or not to come on ???
Air conditioner starting: One 13500 Btu air
conditioner with 3000 W base load or two 11000 Btu air
conditioners with 1500 W base load at 100° F (38° C) at
500 ft (152.4 m) elevation
RV generator set Quiet Gasoline TM Series RV QG 5500
  • What is your RV? Is it 30 or 50 amp? If 30 amp is there a switch to select front or rear?
