wa8yxm
Jul 21, 2019Explorer III
Branson N Tucson wrote:
I believe that if you are only on 30 AMP only one unit at a time will run. 50 AMPS both will kick on.
True but the fans on both may run. (Depending on how it controls them)
Second To the O/P when was the last time you cleaned the condener coils.. often they get a touch ...er... clogged with stuff?
(Mine were last leaned last thursday)
FInally. how did you measure the cooler air. Dont expect 35 degree air if the room is 90 as they can only drop the temp 20-30 degrees in most cases. And high outside temps will reduce effiency as well. and it has been HOT OUT
