Walaby
Jul 21, 2019Explorer II
Hmm... So, good point. The IR thermometer is probably measuring the temperature of the physical intake and the physical output vents, not the actual air temp. Still, when I use mine, it does show a 20+ degree difference between the two physical objects, which would still provide a relative eval, although as you say it wouldn't be an accurate measure of the air temp.
Mike
Mike
