dougrainer
Jul 26, 2019Nomad
obiwancanoli wrote:
A/C still not working properly, but could this be suspect?
When I bought my rig 11/17, I was told by the dealer that the house batteries required no maintenance, and so, I ignored having to check them. In the time I've had my rig, there have been issues with the duration of power when not connected to shore power, forcing me to run the generator more than expected...
As a matter of routine, I checked the compartment, wanting to make sure the gauge on the propane tank was accurate, and behold, there was a small amount of corrosion on a couple terminals of these deepmcycle batteries, and further, I noted there were removable caps on the cells... so, I checked them, and... dry as a bone, every battery. Filled each cell with distilled water, a little more than covering the plates, and we'll see if that improves things.
Made me wonder if they were not producing enough power to fully run the a/c... thoughts? Concerns? Have the batteries become too damaged to avoid replacement? Haven't tried the a/c, it's evening, but the weekend will be hot, so going to give it another go...
Sorry, your assumption is not correct. While it TAKES 12 volts to operate the wall Tstat controls, the AC's run off 120 volts. So, 12 volt fluctuations will not cause your AC problem. You need to REPLACE the batteries. Once they boiled dry, they are useless. They may come back up, but they will never get to 100% operation. Doug
