wvabeerExplorerJun 06, 2022Air dryer purge every 40 secondsHas anyone had this problem? I've check for air leaks on the line to the reserve tank and the line to the air drier all from the governor. A new governor, rebuilt air drier replaced air line from comp...Show More
eHoeflerExplorer IIJun 06, 2022Most likely the pressure relief valve popping off, the regulator on the compressor is bad
Related ContentPurging propane tankBought a second truck.Purging propane tankPropane Tank Vacuum PurgeSplendide washer dryer combo knob
