djbroughton's avatar
djbroughton
Air in water lines
I used my unit all last winter for the first year since buying it and put it away in the spring. I winterized back in September by blowing the air lines. i was careful not to exceed the recommended max. pressure in clearing the lines and followed the owners manual instructions. We are now south for the winter and after filling the fresh water tank immediately found that water would not run smoothly because of air in the lines and the pump would not shut down. I even replaced my Aquajet pump with a brand new spare thinking the diaphram was maybe punctured but both run the same. I checked the debris screen at the pump intake but it was clear and I can see air in the wet bay lines leading to the pump. I cannot trace the intake line fully through the coach back to the fresh water tank (FWT) but the line coming from the FWT does not show air bubbles. There is no water leaking under the coach which would indicate a ruptured line.
After 2 weeks on the road, the air is slowly clearing from the lines and the pump is starting to shut down on demand but it has been a really slow process.
One thing I have decided is that I will winterize using RV antifreeze next year.
Any suggestions and does anyone else have this problem?
