MountainAir05
Oct 25, 2021Explorer II
That the new owner. Newmar prices use to be very good. could you post a picture of the switch and the part number. Also does it have wires to it or just a air /valve. Did you see anything wrong inside it or maybe just dry and dirty. If so WD40 and let soak and then blow dry. If it has 0-rings then lube them , new ones if you can find and try again.
Will see if I can find you one.
38,782 PostsLatest Activity: Aug 23, 2026
