MountainAir05
Oct 25, 2021Explorer II
Cindy and Steve wrote:MountainAir05 wrote:
That the new owner. Newmar prices use to be very good. could you post a picture of the switch and the part number. Also does it have wires to it or just a air /valve. Did you see anything wrong inside it or maybe just dry and dirty. If so WD40 and let soak and then blow dry. If it has 0-rings then lube them , new ones if you can find and try again.
Will see if I can find you one.
This is the backside of it. I removed it and opened it but could only go so far and couldn’t figure out how to dismantle it any further, and I didn’t want to break anything. I had the air pressure at full and the whole time I was tinkering with it air was hissing out of the part I couldn’t dismantle. I’ll try and find a part number. There are no electrical connections anywhere with regards to the step cover. 100% air.
Something has to control that unit. Be it a rocker switch or a something else. If rocker it has wires and goes to another valve that has a solenoid. With the picture someone who drops by might know the info. Looks like the info sticker is on the left side there.
38,782 PostsLatest Activity: Aug 23, 2026
