Cindy_and_Steve
Oct 25, 2021Explorer
MountainAir05 wrote:
Does your step cover make the step inside the Rv or does it just slide out straight and cover the hole.
This is where you get 12 volt actuators when needed.
https://www.firgelliauto.com/
this is the link for the info about maybe your step cover.
https://www.irv2.com/forums/f103/step-cover-lift-motor-114580.html
The cover is also the steps. They don’t slide back and forth as some do, they raise up and down. Sometimes I can force it up by hand and peek under it. There are absolutely no electrical wires at all. Just an air operated cylinder. The piece I’ve shown in the picture is the backside. The front is just a little up/down dial that seems to direct air to the cylinder when turned to the up position.
38,782 PostsLatest Activity: Aug 23, 2026
