larry_cad
Oct 26, 2021Explorer II
I copied the photo, pasted it into irfinview, and enlarged it as much as I could. There is for sure a label on the left side with information that should help us.
It looks like the red and black grommets around the hoses are grippers. If you drain the air out of the system, hold onto the hose just above one of those colored rings, and push the ring straight down, it's possible the hose will pull out of the fitting. To reinstall the hose, just push it down into the fitting.
To remove the box, you will have to remove the "UP" "DOWN" switch knob. It is probably held on with a allen screw on the bottom of the knob. After you take off the knob, there is probably a hex nut holding the box in place. Just educated guesses, but worth a try.
Once you get the box out, post a picture of the label on the left.
38,782 PostsLatest Activity: Aug 23, 2026
