MountainAir05
Nov 18, 2021Explorer II
Bikeboy57 wrote:
Lets see if you get lucky. Many times those push on air line connections leak. Something that works sometimes is to remove the line from the fitting, and snip off 1/4 inch then reinsert. The nylon tubing gets a compression ring in it over time. If the internals of the valve are leaking this wont help. How many wires are connected to the switch. BTW, it is not a switch but an electrically controlled pneumatic actuator
If you had read from the beginning you would have saw that it is a air valve only, no electrically at all.
38,782 PostsLatest Activity: Sep 10, 2026
