etruitt's avatar
etruitt
Air outlet on class A
Was told on initial inspection that the air outlet beside the generator could be used to pump up tires on motorhome with air hose but after reading owners manual it appears that that is only for dumping the air in the air bags. Which is correct? I don't want to carry air hose and connectors with me if the dealer was incorrect. Please advise. Can I use this like an air compressor or not?
  • If it has a quick-connect outlet, you can attach an air hose there. I use mine all the time. I run 105 psi, and it pumps mine up just fine.
  • Both my 04 Endeavor and 09 Sceptor had 2 outlets up front. One was connected to the bottom of the tank and used to expel any water in the tank. The second was for normal use of compressed air. But don't know about your rig.
