edraff
Oct 04, 2013Explorer
I assume you coach is a class A gas. Make sure you know you axle weights when you start off of a trip. Use the tire manufacture tire pressure chart and have pressure what the weight chart advises. Unless you have a temperature change the next morning or you have a slow air leak you should be ok for a few days. If you are worried check tire pressure in the morning before leaving campground. If need adjustment do at the next fuel stop.
