BillMFl wrote:
Weathertodd221 wrote:
JimGo wrote:
Perfect timing-
I have a 2006 W22 chassis that I am installing Firestone Air Bags next Monday.
I already installed the compressor and control valves w/ remote control. Chassis shop will install the bags and run the air lines.
Also installing Koni FSD's at the same time.
Have previously installed front and rear sway bars, front and rear track bars and a safety+. That really helped in the handeling.
Installed a Banks system that improved performance up grades.
Now looking to smooth out the ride. Will post results after testing.
lipstick on a pig comes to mind. I have all those accessories minus the air bag system. Its leaf springs and to try to make a leaf spring vehicle an airbag ride... you are going to spend lots of $$$ for very little benefit.
Also keep in mind... with air bag rides also comes the fact that if the controller valve fails... you wont be able to drive it.
Oink oink. I nearly spit out my coffee! Thanks for the chuckle.
