It took me three days, about half of one was removing the Hellwig sway bar links which are not in the same position as the stock ones and interfered. If you have done that on a 6.7 Ford diesel you know what a nightmare that is. Without that, and better educated, I think it could be done in one long day. It would help to have a complete set of impact sockets up to 1 1/2 inch, and a torque calibrated impact wrench. I spent probably 6 hours just doing the torquing by hand using a torque multiplying wrench. But here is is sitting on air:
One five mile test drive, plenty to convince me that the ride is noticeably better empty. Then I put the camper on, another 5 mile test drive to town and them off to Lake Tahoe for the glider races. What could go wrong?
Good thing I brought a few wrenches along, I had neglected to locktite the adjustable links and they loosened a bit. Seems to be fixed with locktite. While the ride is noticeably improved empty, it is
markedly improved with the camper. With the springs, you would feel the front wheel hit a bump and brace yourself for the rear hit which you know would immediately follow. Now, the front feels harsh, anything the front goes over is swallowed by the back with much more grace. Stuff isn't bounced around in the camper as much. The articulation going diagonally into service stations ramps and the like is more fluid. The thing is even a little quieter. I think it is going to turn out to be one of the best mods I have done to a truck.
