Sprink-Fitter wrote:
How is warming up a diesel motor for 10 minutes a waste? It probably took 3/4 of that to build air pressure.
7 and 1 half minutes to pump the air up? there has to be some thing wrong there.
My air system has automatic water bleeds, it requires nothing from me to dump the water collected in the tanks.
After the coach sets an extended time our tanks will be empty, and it takes about 3-4 minutes at Idle to hear the tank discharge activate.
My routine is:
retract the slides. start the diesel, retract the levelers, walk around disconnect the sewage hose, disconnect the electrical, check to see all jacks are up, walk thru the coach insure the interior is safe to drive, lock the slides. pull away.
