FIRE_UP
Sep 09, 2015Explorer
bob b wrote:
New update. It was the check valve! This is a small one inch rubber face metal disc that works with a spring to maintain pressure. It is located in the dryer just under the fitting for the large hose connection. I removed it and found damage to the rubber seal. Good news,! It is easy to change, cheap, and rewarding to fix. Thanks to the help on this topic. Bob
Bob,
I really want to thank you for getting back and posting the remedy for this issue. First off, not many do and second, I've seen this issue, your same problem, in here and a couple of other RV forums, a few times and, I don't recall seeing what the remedy was. Thanks again.
Scott
38,766 PostsLatest Activity: Jan 10, 2026
