jhilley wrote:
Has anyone used the Harbor Freight or Camping World compressors on motor home tires? I doubt the Camping World compressor will do the job, only cigarette lighter plug.
well if it will fill a car tire in 3 minutes and has a 150psi rating
one will have to assume it will top off a MH tire.Obviously the higher the PSI required the longer it take,s as there is no accumulation of air in a supply tank.These are in my opinion only designed to add a few pound,s to a tire to top off.There certainly not inteneded to fill a MH tire from say 75 lbs back up to 120 lbs in my opinion.Ar least I would not purchase one exspecting such?
there both cigar liter aplications(HF+CW).One could easly change this to run directly off a battery if u so desired
