smkettner wrote:
hershey wrote:
I doubt that the described unit will inflate a basketball.
Nor will the Harbor Freight unit inflate a MH tire.
+1 but get the decent 12v from HF for best results.
http://www.harborfreight.com/12-volt-150-psi-high-volume-air-compressor-69285-8759.html
If the compressor has a cigar plug it is going to be weak.
"Fully inflates car tires in 3 minutes or less" and that is probably a 13" car tire! Can you imagine how long it will take to air up a 22.5 truck tire, and how hot it will be by the time you get it aired up. And that heat is what kills those little compressors.
